Re: IH distributor rotor retainer/spring clip????
Posted by rustred on December 19, 2012 at 10:16:03 from (72.172.100.113):
In Reply to: Re: IH distributor rotor retainer/spring clip???? posted by teddy52food on December 19, 2012 at 09:59:06:
the timing will change cause when the rotor wears on its drive tab timing will be towards the retarded side slightly. every little bit of wear cases timing change, such as lobe wear , point dwell and even timing gear wear etc.
