Farmall A Air-Cleaner (remove pipe from canister)
Posted by Stevie J. Mote on December 19, 2012 at 11:46:37 from (173.55.14.150):
Hello. I have a Farmall A that looks as if someone has cut off the pipe from the Air Cleaner canister. It is almost to hood level. My question to you all is how/can this pipe be removed and replace? If so what is the process and the correct height of this pipe? THANKS
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
