I will assume the "two valve" you are speaking of here is a two spool,3 position,two way,spring to center valve,open center .
Yes you will be able to run BOTH the 3 point and "other" attachment,but NOT at the EXACT same time.(Either one or the other.
Example: The first section of the valve that the "IN" port of the valves you are running .If you are running that function,NO oil is going into the second section of that valve at that time.Does that make sense???
When you stop using the first function in the sequence of the valve,the SECOND section of the valve NOW has oil available to be used.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
