Posted by ihman73 on December 19, 2012 at 18:02:42 from (67.43.125.70):
In Reply to: 1466 duals posted by smalltimer on December 18, 2012 at 15:27:18:
We have a set of duals I believe that were for a 4386 on our 1086. The centers are quite a bit heavier than the nine bolt duals we had on the 1066 we used to have but I'm not sure how many bolts. They are big bolts as well inch I believe, they take a 1 5/16" socket.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
