Must be a pretty good F-12 to be able to pull that plow very fast....Anyhow, adjust the furrow wheel on the tractor so the inside of the tire sidewall is about 22-23 inches from the center line of the tractor which is the center hole on the drawbar. It would be better if the land wheel is adjusted the same or close to it. Now the center of pull on that plow will be about 6-7 inches to the right or toward the plowed ground from the sidewall of the back bottom's furrow and right about where the share joins the moldboard 1/2 to 5/8 down the line from the front. From this point the draft line is straight to that center hole in the tractor drawbar and you should adjust the plow drawbar to follow that line as closely as possible, both left and right and up and down when the plow is plowing the depth you desire.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
