Re: Farmall m valve/belly pump question
Posted by CNKS on December 20, 2012 at 17:55:26 from (216.144.104.128):
In Reply to: Re: Farmall m valve/belly pump question posted by Brady miller on December 20, 2012 at 17:46:17:
They are all pressure out, the return needs to go back to the reservoir. The basic system consists of a lever and rod connected to the pump, assuming you still have it. That is power up, gravity down. Your valves, with the return to the reservoir allow pressure up and down. The lever must be locked to the rear for the valves to work.
