Re: engine info.
Posted by CNKS on December 20, 2012 at 18:15:24 from (216.144.104.128):
In Reply to: engine info. posted by marc walker on December 20, 2012 at 16:07:37:
Marc, you indicated in a previous post that the previous owner said it was a 1965 and came out of a cement mixer. The C135 came in tractors and "power units". If it came in a tractor, it was either a 340 or a 404, not sure if any other models used a 135. If a 1965 it came in a 404, drawbar would be in the low to mid 30's, Tractor data says 36, it is not always accurate. Spark plugs are determined by heat range--lot of discussion in the archives about that, someone will probably come up with a number. The 135 is an outgrowth of the C123 with a larger bore and stroke.
