Re: Farmall m valve/belly pump question
Posted by CNKS on December 20, 2012 at 18:34:45 from (216.144.104.128):
In Reply to: Re: Farmall m valve/belly pump question posted by Brady miller on December 20, 2012 at 18:01:00:
OK, you didn't tell me that you had a factory 2-way valve. You have to have the lower rod pulled back for the upper one to work. You have pressure up and down -- I do not have one of those, but it looks like the return is back to the reservoir. I believe that particular setup only allows one implement or a 3 point. Jim can probably tell you how to use an additional implement, as stated I have never used one of those. But, you can use the lower rod for an implement if you only need gravity drop. The answer I gave above is starting from scratch with aftermarket valves.
