Re: Idle on M
Posted by charlie M on December 21, 2012 at 07:33:33 from (74.41.94.226):
In Reply to: Idle on M posted by Phil in NW Mo. on December 21, 2012 at 07:26:09:
There is an adjustment in the govenors for idle and upper RPM. Just take the cover off and it will be easy to see what you have. On the carb make sure the litle tab from the govenors to the carb is in the slot or you only get one speed - fast.
