Posted by pete 23 on December 21, 2012 at 12:00:37 from (74.32.238.2):
In Reply to: Idle on M posted by Phil in NW Mo. on December 21, 2012 at 07:26:09:
The governor high idle and low idles set screws have to touch their stops when in full throttle and low idle positions. That is the first place to look. If you missed the tab on carb it would run wild if you missed it underneath tab or if you miss in over top you might not even know it until you tried to use tractor to pull a load as the carburetor butterfly would only open about a third. The link between carb and gov has to be free, and is to be adjusted for free pin with throttle wide open and linkage held up for fully open carb butterfly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
