Re: No valve seals found in IH 404 prior to rebuild.
Posted by Janicholson on December 21, 2012 at 15:46:45 from (74.60.94.18):
In Reply to: Re: No valve seals found in IH 404 prior to rebuild. posted by RandyDowdy on December 21, 2012 at 14:45:21:
I opt for the PC Teflon rig seals that meter oil and are more or less standard on modern engines. They are good for a reason. Jim
