Re: Farmall A Transmission joiner
Posted by gene bender on December 21, 2012 at 16:24:32 from (67.55.227.74):
In Reply to: Farmall A Transmission joiner posted by bkpigs on December 20, 2012 at 07:20:18:
Those bolts are tapered and you need to check the plate to see that the holes arent worn 35 on the tourque wrench will be just fine.
