Re: No valve seals found in IH 404 prior to rebuild.
Posted by pete 23 on December 21, 2012 at 18:38:50 from (74.32.238.2):
In Reply to: Re: No valve seals found in IH 404 prior to rebuild. posted by RandyDowdy on December 21, 2012 at 15:59:26:
The guides will most likely have to be machined to
get a flat on top and maybe reduce outside diameter.
Any automotive machine shop should be able to come
up with the specs and a good seal. I no longer have
that information myself. I did a lot of machining
valve guides back in the day as they say. It is
real simple. That and the height of the machined
guide is what is important.
