Re: Farmall. 300
Posted by Janicholson on December 21, 2012 at 20:05:49 from (74.60.94.18):
In Reply to: Farmall. 300 posted by Old weldor on December 21, 2012 at 19:44:01:
No nylon to my knowledge. If it was wet snow at about the freezing point, the throttle plate could have iced up and stuck. Does wide open mean over revving, or just not going to idle. Over revving has the engine turning beyond full throttle speeds, Not good.
A stuck throttle or linkage off of the throttle lever getting stuck at full throttle is different.
If that were the case, it would operate fast, but no faster than normal full throttle. it would be able to sense loads and change throttle position but stay at the normal high speed.
If runaway speed, the throttle either stuck in the carb (shaft or loose plate getting jammed), or the tab in the linkage at the inside of the governor tube to carb fitting broke off. Jim
