Re: M swinging drawbar
Posted by MisterT on December 22, 2012 at 06:00:28 from (216.248.71.226):
In Reply to: M swinging drawbar posted by MJ in the UK on December 20, 2012 at 18:31:26:
Unless you will be pulling a disk or other similar tillage equipment, you do not need a swinging drawbar. A pull type plow is meant to be hitched directly to the horseshoe, and likewise with pretty much any other trailing equipment.
