Re: Idle on M
Posted by MisterT on December 22, 2012 at 06:08:25 from (216.248.71.226):
In Reply to: Idle on M posted by mkirsch on December 21, 2012 at 07:26:09:
The governor is lubed with a "splash" system. Basically, oil is slung into the governor from the drive gears in the front of the engine. It gets just enough oil to keep it properly lubricated, and then the oil just drains out and back into the engine. If you remove the cover, there may be a drop or two of oil that will escape, but not much more. You can even start the engine with the cover removed and not lose much oil, but it will be somewhat messy.
