Seal ? for SM
Posted by pete_5959 on December 22, 2012 at 11:20:34 from (70.63.206.178):
I had to replace the clutch/brake pedal shaft due too excessive wear on the clutch end. I have installed brass bushing on clutch pedal and ready to install new shaft. I pulled out the oil seal and it is quite different than the new one from Case IH. The original says U-17944 and is twice as thick as replacement 380959r91. When I ordered the replacement they sent in 4? Has anyone replaced this seal? Am I to use two on each side? Thanks for any advice...
