Re: Farmall. 300
Posted by rhtx55 on December 22, 2012 at 11:49:42 from (68.185.207.25):
In Reply to: Farmall. 300 posted by Old weldor on December 21, 2012 at 19:44:01:
It is common for ice to form on the exterior ( and interior) of the carb in these conditions, causing linkages & the butterfly to stick. Should be fine after it thaws out. Let it idle for a time when this happens, or cover part of the front radiator to circulate the heat from the manifold, or use a heat houser.
