Re: MD Diesel Bleeding?
Posted by hattrick on December 22, 2012 at 16:13:18 from (199.48.194.156):
In Reply to: Re: MD Diesel Bleeding? posted by D Slater on December 18, 2012 at 07:13:03:
So I know a little more about how this system works now. I had some flow issues in and out of the water trap and have resolved those. When running on gas the guage is still pegged and I have bled the trap and AUX filter. With it running I am able to bleed the Primary filter but still nothing to the injectors. After a minute or so if I bleed the primamry filter again it has air again. If I have pressure from the lift pump through the prmary filter to the pump is it saying that my main injector pump is bad? It also does not seem to matter if I pull the trottle or manually pull the pump arm. Is there anything that I can do to isolate this a little more?
