Re: 1066 starting circuit
Posted by glennster on December 22, 2012 at 17:10:50 from (99.90.9.201):
In Reply to: 1066 starting circuit posted by mike Fitz on December 22, 2012 at 15:34:34:
if it is like the 1486 there is a clutch safety switch so the clutch must be depressed before the starter can be engaged. kind of tricky to find, but take the hood off on the left side of the tractor and look at the fire wall at about eye level. you will see a plug with two wires and a little switch going thru the fire wall. unplug the switch and check for corrosion. you may just need to shine up the connections.
