Re: Farmall h engine troubles
Posted by Hey Old Man! on December 22, 2012 at 17:18:43 from (24.58.218.81):
In Reply to: Farmall h engine troubles posted by Andrew Psencik on December 16, 2012 at 11:50:00:
I had the same problem with a carb I rebuilt on my H. Had to take it apart a second time to clean out a piece of debris in the main jet passage. Ran like a champ afterward. Pull the carb and check all the passages again, especially the main jet. Something is plugged somewhere in there.
