Re: Farmall A trans to PTO shaft
Posted by Janicholson on December 22, 2012 at 20:27:17 from (74.60.94.18):
In Reply to: Re: Farmall A trans to PTO shaft posted by bkpigs on December 22, 2012 at 20:21:03:
Loosen it up and stick a feeler gauge (or the ti[ of two screw drivers in the crack. If the drag goes away, score. If it stays, the solution is not there! Jim
