Re: Farmall A trans to PTO shaft
Posted by Keith Budd on December 23, 2012 at 05:13:13 from (76.247.135.71):
In Reply to: Farmall A trans to PTO shaft posted by bkpigs on December 22, 2012 at 18:55:29:
We had a customer's tractor in our shop recentley with the same problem, we found the collar that engages the shafts to drive had several burrs on it & the engagement lever was bent enough to cause the same problem you have. I would make sure that the lever is pulling the coller away far enough first, then clean up the collar with a file it is alot softer metal than the shaft. The burrs are from all those years of non live pto driveline use.
