Re: WD9 tires and wheels
Posted by WOpp on December 23, 2012 at 08:33:53 from (69.26.31.243):
In Reply to: WD9 tires and wheels posted by 53H on December 22, 2012 at 15:24:03:
Just for the hell of it I went looking at WD9 wheels that I have had chains on. If you use 15 x 34 rims with offset drop center your 18.4 will have room for truck style chains which is what I have used. If you are going to use the 14 x 34 with drop center no offset and 16.9 tires they will run close but light truck chains will work. If you need to run real heavy duty chains find a set of 16 x 34 rims with mounting lugs off a 600 or 650 and 18.4 tires will work with room to spare.
