Posted by pete 23 on December 23, 2012 at 09:35:46 from (74.32.238.2):
In Reply to: 656 Hitch Delay?? posted by TimWafer on December 23, 2012 at 08:25:46:
To verify where the problem lies, put your aux valve on demand and then try the hitch while holding aux valve on . If you have a loader or something else hooked to aux valve you will need to run it to the end of stroke so pressure will build. If the hitch responds immediately when you do that you will know the problem is in the unloading valve. Probably has a sticky o-ring or partially plugged orfice in piston. Problem is you have to take the draft control cyl out to repair it. I cannot visualize the clearance in front of the valve , you might just possibly have enough room to get it out without pulling cyl assembly out but I don't think so. It is under the seat under that flat cover. Far as your draft control lever, it should always be far forward in heavy position,(off) unless you are using an implement that enter the ground like a plow and then it is a rare condition that you really want or benefit from using it .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
