Tractors of that vintage without power steering would be kind of rare. I never have seen one and I worked on them since they were introduced new in 1958. Your problem may be as simple as a backed out set screw, shot thrust bearing on worm shaft or as bad as worn out splines on input shaft. If it is the splines, I have cut the yoke on u joint, welded spacers on them for a bolt to go though and tightened the yoke down tight on splines. As the shaft has to move in and out to shift the spool for power steering ,then you have to adjust the steering shaft so the whole shaft all the way to the steering wheel moves back and forth. It does work. Lots of stuff inside that unit. Takes some work to get them all a part.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
