Re: farmall B 12 volt conversion
Posted by K-Mo on December 24, 2012 at 03:57:51 from (66.43.226.235):
In Reply to: farmall B 12 volt conversion posted by andy H in WI on December 23, 2012 at 16:42:40:
The advantage of converting to 12 volt is the alternator.
For starting, the 6 volt system works just fine. However, the generators have a low output and the mechanical regulators can be troublesome. When the tractors were in the field for long hours, the generator had time to recharge the battery. Now days they don't get enough continuous run time to recharge the battery.
The alternator has a high output for quick battery recovery and an internal regulator.
With good heavy battery cables, good starter, starter switch and battery, starting should not be a problem. It is important to insure the battery is fully charged while sitting the the shed. A good automatic battery charger or maintainer can be helpful.
