Re: H oil pressure
Posted by DeltaRed on December 24, 2012 at 07:21:47 from (67.6.219.50):
In Reply to: H oil pressure posted by mainamana2 on December 24, 2012 at 04:41:30:
There is no "correct" oil pressure.As long as you are in the operateing/safe/green range it is safe.It all depends on engine wear,bearing clearances,etc.Take two new identical engines,they will each produce different oil pressure readings.As long as the gauge says 'safe' and the crankcase/oilpan is full,run it,no worries.
