Re: Ok, newbie question of the year probably.....
Posted by john d on October 30, 2000 at 05:40:41 from (206.141.74.34):
In Reply to: Ok, newbie question of the year probably..... posted by Jim on October 29, 2000 at 15:56:24:
Not a bad question at all!
Just keep in mind that there really ISN'T a "magic number" that you can rely on for complete safety. Even on a hilside that you've traveled many times before with that same tractor you can get into BIG TROUBLE very quickly due to such variables as hitting a small rock (or soft wet ground) with one wheel, a little more speed than usual, a passenger on the drawbar (NOT a good idea...) etc. The center of gravity on your H will even vary as to how much fuel is in the tank!
Adding the gauges would be a good idea, but won't prevent the thing from going over once it starts!
Post A Followup
: Re: Re: Ok, newbie question of the year probably.....
