Re: 12V Generator
Posted by gbs on December 24, 2012 at 17:00:03 from (71.51.253.69):
In Reply to: 12V Generator posted by pete_5959 on December 24, 2012 at 15:31:19:
if your 6 volt generator is good you can use a 12 volt regulator with it and it will work fine the 6 volt gen can produce 17 volts sufficient for volt system,i have and h and know of a couple more setup this way, had the gen checked out buy a rebuild shop he matched a regulator and told me he disconnected the third brush my gen had because it used a cutout relay instead of a regulator originally,only draw back is most gen won't charge at low rpms
