Re: Farmall Smta won't start
Posted by old on December 24, 2012 at 17:49:54 from (209.86.226.32):
In Reply to: Farmall Smta won't start posted by Brady miller on December 24, 2012 at 17:24:23:
Spark has to be a good blue/white and jump no less then a 1/4 inch gap no matter what to run. Also if you have gas running out the bottom of the carb you have a flood engine and poor spark and flooded do not mix. Clean and or replace the plugs and check/clean the points and be sure they are gaped as thy should be
