Re: Farmall Smta won't start
Posted by The tractor vet on December 24, 2012 at 18:04:32 from (75.24.0.186):
In Reply to: Farmall Smta won't start posted by Brady miller on December 24, 2012 at 17:24:23:
With a S/MTA or any up draft carb you will have some gas dripping and sometiimes running out of the carb once you stop cranking it. Now first thing i would check is to make sure that the piston one #1 is at the top of the compression stroke and that the rotor is under #1 plug termial . also do a compression check on the engine and see what you have on all 4 cylinders . If the rotor is way off you may have and issue with a sheared key on the cam gear or even a broken cam gear. Also make sure that the distubtor is turning and that you have spark at the points and plugs. I don't know what is going on with the points today but for some reason they get a crust on them and they will not make contact. see this alot anymore , even seen new points out of the box that will not work.
