Posted by robgIN on December 24, 2012 at 18:12:40 from (70.224.33.199):
In Reply to: late model f-20 posted by Johnf20 on December 24, 2012 at 15:43:08:
take one of the block inspection covers off and feel the sleeve and see if it feels really thin. It may have 4 inch pistons in it. If they put an M carb on it I wouldn't be suprised if they put the big piston and sleeve kit in it too. They do crank a bit harder with them in so that electric start will be a plus if it does.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
