Re: Farmall Smta won't start
Posted by El Toro on December 25, 2012 at 08:44:24 from (108.3.143.30):
In Reply to: Farmall Smta won't start posted by Brady miller on December 24, 2012 at 17:24:23:
If you have a distributor make sure your battery is fully charged. Check the specific gravity using a hydrometer of each cell and write the readings down. Should see 1.280 on each cell.
If the battery voltage is dropping too low during
cranking you may not have enough battery voltage for the igniton. Hal
