Re: Farmall H question
Posted by hayfarmer on December 25, 2012 at 11:43:03 from (71.80.194.62):
In Reply to: Farmall H question posted by farmerwannabe on December 25, 2012 at 10:25:46:
Nice looking tractor(both). When it gets under load and starts to sputter try pulling the choke out. If that helps it is probably a fuel supply issue. Have you adjusted the load jet on it at all? If it is a supply issue work backwards from carb. Disconnect line there to see if you are getting full flow, if not go back to sediment bowl. sometimes something in fuel tank bocks outlet.
