Re: Farmall Smta won't start
Posted by IlliniJohn on December 25, 2012 at 15:00:54 from (173.26.154.98):
In Reply to: Farmall Smta won't start posted by Brady miller on December 24, 2012 at 17:24:23:
Agree with checking timing, check point gaps.
My old SMTA had sat for several years when I got it, cleaned carb, checked fuel flow, replaced points and condensor, checked valve opening & closing with rocker arm clearance, and it had spark at end of PLUG WIRES-to-ground, but wouldn"t hit a lick. Turned out All of the plugs would not fire. Replaced plugs and it is the absolutely easiest starting tractor I have ever had.
Best Wishes!
John
