Re: Farmall Smta won't start
Posted by mkirsch on December 26, 2012 at 05:17:49 from (64.80.110.75):
In Reply to: Farmall Smta won't start posted by Brady miller on December 24, 2012 at 17:24:23:
What's wrong with both?
Check battery voltage. If it's low you know you've got a problem. Investigate further by checking specific gravity.
Low voltage by itself will tell you whether or not a jump start or booster might help. At least you can get the tractor running to get the job done.
Specific gravity will tell you whether or not you need to replace the battery. That's something you do at the end of the day when you're finished with your work.
