Re: painting Super A
Posted by gn on October 30, 2000 at 09:42:54 from (208.223.205.166):
In Reply to: painting Super A posted by Ricky on October 30, 2000 at 08:28:31:
Ricky..the usual proceedure when doing automotive jobs is to sand the metal with 80-120 grit paper, then prime it. This eliminates the "bullseyes" where there is bare metal and primer/paint. Next fine sand it with 400 to 600 grit paper (for cars we usually wet sand). If you leave sanding marks, they will show. The whole job is dependent on how good you prepare the finish before you paint.
Expensive paint won't cover up a bad prep job. Do not forget to get a tack cloth and wipe everything down before you spray. This gets a lot of the dust off. Others say don't use a tack cloth because you leave dust, but I have found it a lot better to wipe down. Some guys even wet down the floor first to eliminate any dust coming up off the floor. good luck..gn
Post A Followup
: Re: Re: painting Super A
