Re: cold temps out side and my H wants to stall
Posted by Janicholson on December 26, 2012 at 21:01:02 from (74.60.94.18):
In Reply to: cold temps out side and my H wants to stall posted by ericy on December 26, 2012 at 20:20:30:
The fuel probably has some ethanol in it. Water is possible, but the tractor (if it just stalled without sputtering) might be having an electrical issue. If it did sputter and die slowly, it could be carb icing. Especially if it was at or near freezing. Carb icing is pretty common and the humidity in the air freezes in the carb, restricting and flooding it as it seems to choke out. It will restart because the warmth of running melts the ice. Jim
