Posted by D Slater on December 27, 2012 at 04:24:08 from (184.15.46.232):
In Reply to: Farmall M mw 9 speed posted by jim warehime on December 26, 2012 at 20:22:20:
Also the M&W transmission input shaft and 4th and 5th sliding gear is added. Small gear on the side which is the reverse idler gear is not effected unless one unit has a low low first gear and not the other unit. If both units have standard gears the standard IH reverse idler gear is used. With standard gears everything forward of 1st and second gear is changed on the countershaft until you get to the counter shaft front support bearing.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
