Susan - As the others suggest, work the tractor HARD for 10 - 15 minutes (run it wide open and with as much load as you get manage). Then allow it idle no longer than a minute or so before shutting down. This will burn out every trace of moisture and gunk from and leave the manifold/muffler dry inside.
Now presuming there is no coolant leak in the head your next startup will be "clean".
ALSO if your tractor has an inoperative thermostat - or if the t'stat is missing - install a new one so the engine operates at the correct temperature.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
