Re: how to get read of Carbon and fuel residue in the muffler
Posted by JRSutton on December 27, 2012 at 08:47:44 from (75.130.109.233):
In Reply to: how to get read of Carbon and fuel residue in the muffler posted by susan a on December 27, 2012 at 06:27:19:
Carbon comes from gas that isn't burned completely. Usually from putting too much gas in through the carb.
You'll always have SOME on an old tractor.
Are you leaving it choked when starting it? Open the choke up immediately when it starts.
Also might want to try leaning the carb a bit.
If you do that - be sure to test it under load to be sure you didn't make it too lean. And also check your plugs occassionally to be sure you're not running too lean.
