Re: cold temps out side and my H wants to stall
Posted by d beatty on December 27, 2012 at 11:56:10 from (205.188.117.74):
In Reply to: Re: cold temps out side and my H wants to stall posted by d beatty on December 26, 2012 at 20:46:04:
d beatty is the winner!!!! I looked in the tank today and guess what !!! a d@mn bug was floating in the gas thinking that the bug would get sucked down in to the sed. bowl and block it off then would refloat!!!!!!!!so I fixed that --took off the gas line with a piece of tin like a rain gutter under the sed. bowlI removed the sed bowl assby. and drained the gas tank out the sed bowl hole that flushed out the bug-rust ....NOW HOW DID A D@MN BUG GET IN THERE???
