Re: 656 Hitch Delay??
Posted by pete 23 on December 27, 2012 at 18:22:42 from (74.32.229.189):
In Reply to: 656 Hitch Delay?? posted by TimWafer on December 23, 2012 at 08:25:46:
The unloading valve is under the plug farthest to
the right when you are standing behind looking
forward and down on draft control cyl with cover off
under seat. Snap ring, plug then piston. Will be a
small orfice in the piston so blow back and forth
through it. You can look inside farther to make sure
there is nothing under the ball inside. That seat
for ball screws out but should not be necessary to
go there unless damage to ball or seat.
