Re: 584 hydraulics problem HELP
Posted by ben brown on December 27, 2012 at 18:23:32 from (184.63.225.47):
In Reply to: 584 hydraulics problem HELP posted by warren woodrow on December 27, 2012 at 15:45:07:
where the filter canister fits up there's a o-ring behind it my bet is you pinched it and now have a air leak take it off make sure the o-ring is in the grove and is not cut replace canister see if that don't work up under the finder where the filter is located it real easy to cut the o-ring also don't let canister turn as you are tightening it up as that well also case you problems as sometime the o-ring well move out of the grove
