Re: Bearing noise 484 IH
Posted by jimb2 on December 27, 2012 at 18:39:16 from (174.114.182.155):
In Reply to: Bearing noise 484 IH posted by Martin Reece on December 27, 2012 at 13:22:29:
Hi Martin,
I looked in my I&T manual and it does not give any instructions about replacing 540 RPM PTO bearing only how to replace the complete shaft. IIRC neighbour changed PTO bearing on his 4210 from the rear.
Before tearing it apart, I would check the bearing by using an old broom handle held against the bearing cover and the other end against your ear and listen for the squealing noise. BECAREFUL NOT to get tangled up in the PTO.
JimB
