Posted by 9598Farmallred on December 27, 2012 at 20:38:57 from (64.194.68.234):
In Reply to: Bearing noise 484 IH posted by Martin Reece on December 27, 2012 at 13:22:29:
Quoting Removed, click Modern View to see Martin, yes you can replace the bearings without splitting tractor all you need to do is remove rockshaft cover there is a snap ring behind the gear you will need to remove, also the seal & rear brg. retainer, check the inner brg. bore in the rear end housing as these brg,s would fail and eat the bearing bore away this can also be repaired fairly easily by a machine shop without further disassembly. I hope this helps Andy.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
