Re: Checking transmission fluid on 1951 Farmall C
Posted by gene bender on December 28, 2012 at 06:20:03 from (67.55.227.74):
In Reply to: Checking transmission fluid on 1951 Farmall C posted by vet119 on December 28, 2012 at 06:08:02:
That plug is where you check the level its supposed to be full at the plug. Mite want to drain and flush then fill with new.
