The plug your looking for is a 1/4" plug on the right side of the trans housing. It's at the back corner close to the same level as the PTO shaft and axle.
The 1" fill plug is on the top deck next to the shifter. It takes a 1/2 ratchet to unscrew.
You fill the trans until it comes out the 1/4" plug.
The drain plug is at the center/bottom of the trans housing.
Unscrew the drain plug and get a sample of your existing fluid. You may get a shot of water then oil. If it's clean top it off. Not clean will look milky, brown, goopy crap that may not drain at all. You may need to poke a through the crud to get it to drain. Last one I did took several days to drain and stop dripping.
If it's bad I drain it and dump 5 gallons of diesel in. Then go for a easy no load spin around the yard and let it sit for a day. Drive it around again and then drain and refill.
Takes about 5 gallons, I use 85w-140 gear oil. Book calls for straight 80w-90.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
