I converted my SMTA to 12 volts when I first got it. For one thing I use it to run a baler at night and 6 volt lights and hard to find. I also had it changed to a contact on top so I could use a push button start instead of the original starter switch. Most of the Ms I ran over the years never turned very fast with 6 volts. It is a longer distance from battery to starter on SMTA than a standard M so I think you would need a really heavy cable, like a made up welding cable, to really get the power to starter with 6 volt.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
